Aion 2 not working?
Aion 2
  • Game Server Location: Asia (Taiwan)
  • Node Mode: Basic mode
  • Selected Mudfish Node
    • DE Europe (Germany - Amazon EC2 3)
    • FastConnect mode ON
    • WFP item mode ON
I cannot get into the login server. Is it just me?
Hello,Thank you for reaching out to us. To get started, could you please confirm whether How to check the basic functionality is working correctly in your environment? This is the first step we recommend. If you encounter any issues, please let us know, and we’ll be more than happy to assist you further.
Ok, so it seems it’s not a problem with Aion 2. The basic functionality is indeed not working… But I’m pretty sure it worked in the past on this PC. I tried all the ports. Full VPN mode doesn’t actually change my IP.
Edit: I reinstalled Mudfish and the basic functionality is now working, but Aion 2 item is still not working. Can’t correct to Aion 2 login server.
Edit 2: I haven’t used Mudfish for so long I forgot how it worked. Didn’t know I had to add nodes from Taiwan manually, because I had only 3 nodes from Germany for Lost Ark.
It’s working now with the below settings:
  • TW Asia (Taiwan - Amazon EC2 3)
Hello! I’m really glad to hear that it’s working for you now.
It seems this issue was caused by how the node list restriction is configured in the ‘Setup → Nodes’ menu. Because your list was restricted, the Taiwan nodes you needed were hidden. Adjusting that specific setting to show the required nodes is exactly the right way to resolve it.
Have a great time playing Aion 2!
