Hi Mudfish Support
i would like to ask abt black dessert online japan server,i realize mudfish vpn cant be approved by http://blackdesert.pmang.jp/
i find some problem at below
Problem 1:player would like to login at the website but login button was no respond.
Problem 2:Tried Full Vpn mode,problem is the same or else Mudfish Configuration keep stay on 10%,no matter using which JP VPN.
Problem 3:Tried compare with Soft Ether is able to login, is bcs when using Soft Ether browsers it chg to google.jp but mudfish won’t
Hope Support can able to fix this problem or give some advice
Ah… it’s provided ‘pmang.jp’; if I know correctly, they has a strong restriction policy from outland access and most of IP ranges used by Mudfish were blocked. Could you try with the following steps?
* Sets Full VPN mode with ‘JP Asia (Tokyo - SoftBank)’
* Opens http://myip.mudfish.net then checks the message is shown correctly.
* Try to http://blackdesert.pmang.jp/
If this step isn’t working, it means all of Mudfish Japan nodes are blocked. To solve this issues, only a way I can do is that finding a new Japan node which isn’t blocked yet by pmang.jp.
Last time I played, most of pmang’s restrictions are on their website rather than the game.
1. Run softether vpn.
2. Run mudfish with the BDO active item configured for a japanese node (at this point, mudfish’s vpn is running through softether)
2. login to pmang and start up the launcher
3. start the game with the launcher. The game should connect to its auth server through mudfish through the softether tunnel
4. when you get to the game title page (before you press start) turn off the softether vpn. Wait for it to completely switch off.
5. check to see if mudfish is still working. I think it will restablish it’s connection–don’t recall. If it doesn’t, you can restart it.
6. Press start on the game and continue to play.
4 & 5 might have to be altered a bit. You might have to switch softether off later or earlier. Depends on how pmang has changed things since I last tried this. You may also have to keep mudfish turned off until the game start or channel pick screen–depends on networking.
Seems like the error stopped showing.
