can someone help me to configu
can someone help me to configure my mudfish? i use this for fortnite, im usually getting 110 on my ping. when i’m use mudfish, it seems like no big diffrent, im still getting 100+ ping.
yes i did sir, i try to change to full mode vpn, still get the same ping. i think there is no diffrent when i use this program and not use it. i live in indonesia and want to play fortnite in asia server incase u can help the configure
Please check my last answer first because it seems your fundamental issue is from your ISP when I checked your RTT stddev values to mudfish nodes.
so there is nothing i can do ? ok
In my opinion, first you should fix your ISP issue first because without fixing it Mudfish can’t do much to solve this issue. :frowning: Sorry for this news.
