Can you please help me to be a
Can you please help me to be able to access this to play games like dota2 or CS:GO in a short period of time? I would like to test if it affect my ping first. Thank you!
I set the note in auto-mode, the node Hongkong-klayer was chosen and I used that to connect to HK-faceit server of CSGO. In the dashboard I saw that ping around 35 to 40. Last night when I play, it chose Japan server with ping of around 100. However when I restricted and allowed the game to connect to HK-servers only, I have more than 150 ping.
I live in Vietnam. This happened in the last 2 days. Before, the first day I use mudfish I have around 50-70 ping, which is really great.
I’ll try to dig in the FAQ. Do you have any more recommendation for me?
Thank you very much for responding :)
Could you explain this part little bit more?  How did you restrict to pick a node within Hong Kong nodes?  At least Mudfish doesn’t have a feature to limit the selection between specified groups.  If you’re referring to “Node Manager” feature of “Setup  →  Nodes” menu, it’s not affected by “Auto Selection” mode for game items.
Hi,
Now I can’t even run the program properly (cannot open dashboard). everytime I run mudfish I have an error message: mudfish laucer error.
CreateProcess failed with error 0x2
Function runit 577
Error MUDEC_00022
Umm… Weird.  Could you please check Mudfish Launcher isn’t working link for this case?
