Hello, I’m currently using mac OS catalina and when I downloaded the client and tried to install it, it says that the file is damaged hence i’m unable to use your services. I was wondering if you could fix it as I would very much like to use your services.
Could you please show a screenshot of this issue? As you might guess, our dmg package isn’t signed yet. So Mac OS X could show a warning regarding to certificates. Please check https://docs.mudfish.net/en/docs/mudfish-cloud-vpn/desktop-howto-use/#mac-os-x link when you get a chance.
MY mac keep telling me to trash it every time i try to open it after download.
Having the same issues, its not a signing issue as the DMG is downloaded and run no issue.
The problem is the app is detected as not running properly, is the app 64 bit? as Catalina will not allow 32 bit apps to run anymore. I am keen to use your services as many have said its great but unless the app can be made to work on Catalina its unlikely anyone will
Could you please test with http://mudfish.net/releases/mudfish-5.2.2.dmg file? We’d uploaded v5.2.2 for testing purpose.
