Could you add a node for Palad
Could you add a node for Paladins;s Australian servers please? I have already uploaded the packet to the forum, can you see it? Cheers.
Hello loxch, because I been playing Paladins using Full VPN mode and it
ate up a lot of my credits, is that normal?
Unfortunately yes depending on your traffics. :frowning: However I’d reset your credit for you.
Once if you added nodes for
Australia server for Paladins on the item list, will it use less
credits?
Yes definitely. :slight_smile:
패킷 덤프 보내주셔서 감사합니다. :slight_smile: 제가 아이템 업데이트를 해보았는데 한번 테스트 부탁드리겠습니다. 시도해 보시고 여전히 제대로 동작을 하지 않는다면 말씀해 주세요.
잘 작동되는거 같습니다.
