Create custom item won’t work! I tried to add konachan and yande.re because my country had blocked it. But i’m still blocked. I have tried to open it from both web browser and konachan app, but nothing seems to work. Thank you.
The reason why I use add item is to prevent the full VPN service. Also browsing from the said app is far more convenient rather than browsing it from the web browser.
Here would be what I’d do for it:
1. Using Inspect feature of Firefox or chrome browsers, I’ll travelse the site which hostname or domains are used for that side.
2. After sorting out domains, I’ll try to lookup IP ranges of the site using ‘ping’ and ‘whois’ command.
3. Based on these information, I’ll create a custom item. :-)
Here is a example for Firefox:
1. Clicks a right click on the page then clicks “Inspect Element”.
2. Click “Network” tab. After that please visit a site you’d like to access.
3. At “domain” section, you can see all hostnames used by this site. :-)
