Do we still need to have an it
Do we still need to have an item active before being able to equip a custom item?
Because before I had to have another game active (Overwatch in my case) to be able to activate Lineage 2 Revolution as a custom item. That was okay then since I would still occasionally play Overwatch but now I don’t really play so I don’t really want to pay for an item I won’t be using.
If the old system is still active then can you add Lineage 2 Revolution (SEA servers) to the list of games? It’s a mobile game.
Thanks!
If your data plan is Subscription, yes it’s required. Or you can create the custom item without any equipment if your data plan is PPT (Pay Per Traffic).
Oh… can’t you just add Lineage 2 Revolution then? The 3 other Lineage games are in your list anyway. Lineage, Lineage II and Lineage M.
To add new game server, I need some game packets to analyze.
Hmm, I’ll try testing it with PPT again. There was a bug before where I was getting charged hundreds of megabytes a day when the game was just using up .55-1.5 kbps.
I’ll update you if I’ll need to have it switched back to subscription.
Thanks!
Can you switch me back to the subscription option?
Looks like PPT is still kinda bugged for me. I’ll just sub to 2 items like before.
Thanks!
No problem. :slight_smile: I’d changed your data plan to Subscription and reset your changeable date too. If you’d like to change it back I think you can do again.
