For some reason it will not le
For some reason it will not let me change from subscription to pay as you go…why is this?
Did you change it without intension?  It’s only available to change once per month.  However I’d changed it back to pay-per-traffic.  Please log out and in again to be applied properly.
i don’t have the game running yet data is being used, is the vpn always turned on even when i have it turned off?
No.  But you should check Why my traffic get wasted while I am sleeping? section too if you ran Mudfish before.  It takes some time until your credit is charged.
i turned off the game from my settings and i refreshed the real time traffic and data is being used on it, infact it seems that real time traffic is working like a VPN and not just for the game
:-) I don’t think so when I reviewed your connection logs.  Because you enabled ‘Connection Logging’ feature, I think you can see the access logs for details.  Please review and let me know if there’s any entry it seems it’s wrong.
Thank you for sending the packet dump. However did you send this to ask registering new game? If then please explain little bit more for me about what it’s.
혹시 아이템 설정 메뉴에 들어가셔서 중계 서버 설정을 FAQ-중계 서버 관련 문서를 기반으로 직접 설정하여 시도해 보셨는지요?
혹시 한국롤을 접속하시는 것이라면 중계 서버가 되는 서버가 있고 되지 않는 서버가 있으실 것입니다. ㅠ.ㅠ
