Haven't been able to play Blac
Haven’t been able to play Black Desert RU for 24 hours. Fails to connect, St. Petersburg node maybe not working?
I am using Basic mode. still can’t keep a connection. It’s been 7 days now
Why are you using ‘Setup -> Nodes’ menu settings? Did you try to use other mudfish node too?
I have tried the other nodes, none of them allow me to connect or stay connected. This has worked for me for the past 2 years, I don’t understand why it won’t work now.
Which mudfish nodes did you test? And even same by changing Connection Protocols to TCP based?
Thank You! I changed it to TCP based and that fixed it! It has stayed connected for 8 hours now! Thanks so much. :slight_smile:
