hello I from TaiwanThe VPN is very easy to useLow ping No lossWhether it is Korean server or Japanese serverBut we are difficult to pay in TaiwanMaybe you can find Mycard cooperation
First please test How to check the basic functionality with korea mudfish nodes after setting Full VPN mode. If it shows it’s fine at http://myip.mudfish.net site, please try to access the game.
If http://myip.mudfish.net site says it’s okay but it’s not accessible to game server, please try to use other korea nodes.
hello sometimes show error MTU
and i use mtupath and test overwatch korea server
tell me 1422 is good for me
so i change A http://i.imgur.com/RDhxDEo.jpg
Is there a problem that B needs to change? http://i.imgur.com/9CGXgoY.jpg
and if i change MTU i will get high or lowping?
or fix overwatch loss packet?
but when i change MTU show this … [1614.011316] [MUDEC_00269](http://mudfish.net/docs/en/vpn/errorcodes.html#mudec-00269): udp_relay: TOL_sendmsg(2) to 0x60cefe79:26522 failed: 55 No buffer space available
i know MUDEC_00269 mean
MUDEC_00269 will cause any problem?
