Hello, i’m having issues getting mudfish to work all of a sudden. When i open the app and it opens the site for me to “login” i am unable to do so. I enter my username/pass but it never loads the dashboard…nor does the “connect to network” thingy pop on via windows.
What happens after when you enter you ID / password at sign-in screent? Does it show a blank screen? I think you can find more detailed logs (mudrun_stdout.txt file) at Mudfish installation directory. Please check it whether there’s a warning or error message.
This it’s not an issue at all because its error level is INFO. So it doesn’t affect your connection at all.
Did you check that the basic functionality of Mudfish is fine? If not please follow below steps.
Please set Full VPN mode.
Then visit http://myip.mudfish.net whether it shows you a proper message.
Hey, could you help me create a custom item for dota 2 targeting a specific dota 2 game server or is it possible to do it on mudfish ?
Is there any tutorial specific for setting up mudfish for dota2 ?
I’m not sure Dota 2 link is helpful. However could you please test How do I know if its working? section while playing the game? I need to check that Mudfish works fine for game server.
Do i need to restart my connection or pc in order for the settings to take effect ?
Nop. ![]()
Yes you can do it based on Create Custom Item. However if you think Mudfish does not work properly for your game, please try to use one of methods at Unsupported Games.
