Hello Mudfish Tech,
Mudfish doesn’t seem to be working for me for FFXIV as the game doesn’t disconnect when i turn the node on/off. I have changed nodes, reinstalled mudfish, and switched from UDP to TCP… still nothing. It also always gets stuck at 10% auto configure but when i refresh it always goes to 100%. It used to work completely fine when i used it a few months ago but for some reason it does not now.
Edit: It always auto configures now without hassle, however turning the node on and off doesn’t disconnect the game. However when i PING the IP address using cmd, the ping is lowered when i turn the node on VS off… Im confused
Any help would be appreciated.Thank you
Did you try to terminate a mudfish program completely too?
