Hello,   whenever i try to cre
Hello,
whenever i try to create a custom game or join one (League Of Legends)
mudfish throws this error (Admin Dashboard)
MUDEC_00179: Path MTU is wrong. (464/1450)
Did you try to use other third party tools which changes your MTU value of network devices on OS?  It seems you used it in the past and that’s a reason why you’re getting this small value (464, 571 bytes).  You should check your network adapter’s setting first (not Mudfish configuration itself) and restore its value to default value (1500).
Not sure with current collected information.  When you get a chance, please send me Problem Report to let me see more details.
문제점 보고서를 보내주셔서 정말 감사합니다. :slight_smile: 혹시 미꾸라지를 사용하시는데 문제가 있으신지요? 그렇다면 조금만 부연해 주시면 제가 좀 더 도움을 드릴 수 있을 듯 합니다.
