trying to play Mobile Suit Gundam Online. the problem is in order for the vpn to work you need to have it go threw the Bno_starter which is a launcher for the game. and because it’s not one the list I can’t play said game. I wont use full vpn mode because the whole reason I paid for this is that I wanted it to only affect the game
I only have to add mobile suit gundam online here and then it works out of the box.
create a shortcut to the gundam online EXE itself, right click on it, go to properties, and add “./data” (no quotes) to the end. it’ll allow you to launch the game without the launcher, but you’ll need to use the launcher to patch when needed
see if that helps
fullvpn 모드를했을시 제 아이피가 완전 일본아이피로 바뀌는건가요 아니면 다른방식인가요?
일본 팡야를 할려면 아에 접속지역이 일본으로 나와야하는데
미꾸라지 키고서 설정을해도 구글 들어가서 내아이피확인 하면 대한민국이라 안되는데 미꾸라지식 아이피 확인을하면 일본서버로 되었다하고…
