Hey I have problem, I try to p
Hey I have problem, I try to play Japanese game that is unsupported but I haven’t had success yet, I can play this game by using softether VPN program but not with mudfish, the game is warrock.playgra.com and its started from the browser while the game client is on my pc.
Can you guys help me with this?
Did you check Unsupported Games link before?  I think you can try to use Full VPN mode first if it’s not a supported game.
I was actually able to find better connection by going trough all the Japanese nodes available, I was able to get 234 ping this time and its alright, with wtfast and 2 nodes I was able to get ~200 and very smooth experience.
And I will try the manual Full VPN mode double node now, I’m not sure if I understood how to use it though, I will ask help here if I don’t know how to do it.
I have done the Packet dump now, what can I do next? I’d really like to try double node.
:-) I’d created the game item.  Please test with it.
이럴 경우 가장 중요한 것이 기본 동작 여부 확인입니다. 우선 해당 부분부터 제대로 동작하는지 확인하시기 바랍니다. 만약 이 부분이 제대로 된다면 Full VPN 모드를 해제한 상태에서 아이템 설정의 중계 서버를 변경하시며 테스트를 해봐주세요.
