Hi, I couldn’t connect to Maplestory Taiwan server this morning.
I could tho, yesterday
Hi, thank so much for your reply. I have tried to Full VPN mode but things got worse. When I used Full VPN mode, my mac can connect to websites, but my parallel desktop (win7) can’t. So I turned off Full VPN mode.
The only way I can play TW Maplestory is using TW Hotingside without Full VPN mode. All TW Google nodes don’t work with me. I wonder is there any way to fix this?
Thank you.
When you tried to test Full VPN mode, did you use TW Hostinginside nodes too? At least it should work to connect your game server. However are you running your game inside the parallel desktop? Then are you using Mudfish program for Windows or for Mac?
