hi i have 8.35 GB traffic bala
hi i have 8.35 GB traffic balance left long it takes if i play everyday? coz my balance left is 99 cents now i just add my balance last july 13 of total amount 3 dollars now 99 cents left. so maybe i can save if i do monthly plan subscription. pls let me know. thanks.
Hi. This is mudfish support. When i checked your log, i recommend subscription data plan for you. If you change the data plan, you will save the money. But, before change the data plan, please check Data Plans document.
A reason all items were disappered was that you changed the data plan.  It’s very normal.  However please note that at subscription plan, it’s a kind of pre-paid concept; mean that you paid a item then use it for 1 month.  So now you’d equipped “Riders of Icarus” item and valid for 1 month. :-)
If you have any other questions, please let me know.
처리해 드렸습니다. :slight_smile: 확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
