Hi, I have a question about th
Hi, I have a question about the credit consumption while playing Overwatch. I’ve noticed that when I play on Mudfish VPN, it usually takes around 5-10 cents per hour. I also like to stream my gameplay on Twitch, and I’ve noticed that it seems to take considerably more credit while I’m streaming, upwards of 50 cents per hour. This is a massive difference because I play the game several hours every day, so it adds up. To my understanding, nothing other than the game traffic should be affecting the credit consumption, so I’m very confused as to why this is happening. Is there any explanation or a possible fix for this? It ends up being somewhat expensive when I play 6+ hours a day most days of the week.
First sorry for this incovenience. Unfortunately I think your issue is related with Amazon EC2, Twitch and Mudfish and CDN and Mudfish links. Please read these documents. However I’d reset your mudfish credits little bit.
So basically there’s no way to solve this issue other than potentially solving it by doing Mudfish with Proxifier? It seems pretty technical. I appreciate the credits in the meantime. Is there any simple solution you can think of? Anything I could change in my OBS connection to twitch, like the server location or anything?
Unfortunately there’s no a simple solution for this case because Mudfish is working based on the routing table. As you might know, Twitch is a part of Amazon and thousands of Overwatch game servers are operating on Amazon. So it’s almost impossible to ditinguish which IP is belong to Twitch or Overwatch. :frowning:
