Hi. I have been using Mudfish for more than 2 years, but the connection of VPN seems not working. I use Mobile Suit Gundam Online and Gundam Diorama Front, which requires the connection from Japan. Even though I set up my items, I have a connection problem. I also tried Full VPN mode using Tokyo Node, but during this full VPN, I cannot see any internet pages. So I think it is not the problem of the game, but it is a problem of VPN. I use windows10.
:-) Thank you for using Mudfish more than 2 years.
Did you check the basic functionality of Mudfish as follow?
Please enable Full VPN mode then restart Mudfish program completely
Visit http://myip.mudfish.net site after that auto configuration is completed.
At least you should see the proper message at there.
Thanks for the accurate diagnose. I changed protocols and it worked. :)
미꾸라지에서 RTT 가 3000 ms 라고 나온다는 것은 현재 사용자님의 컴퓨터와 선택하신 중계 서버간 통신이 제대로 되지 않아 어디선가 패킷 로스가 난다는 것을 뜻합니다. 우선은 기본 모드 위주로 중계 서버를 변경하셔서 시도해 보셔도 같은 증상이신지 확인해 보시고 그래도 여전히 문제가 있다면 기본 동작 여부 확인 을 한번 해보시기 바랍니다.
