hi i keep getting tol_connect
hi i keep getting tol_connect error . connection refused
Please try to use other mudfish node or check “Status -> Process” menu.  Not sure that this issue is interrupting your connection or not.  Depending its log level such as INFO, WARN or ERROR, my opinion is different.
i keep getting this
[145.598927] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [145.598927] [INFO] MUDEC_00038: TCP relay from the client (10.254.245.162:54907) to the backend (10.249.48.1:8081) failed. [146.856042] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [146.856042] [INFO] MUDEC_00038: TCP relay from the client (10.254.245.162:54916) to the backend (10.249.48.1:8081) failed. [151.687297] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [151.687297] [INFO] MUDEC_00038: TCP relay from the client (10.254.245.162:54920) to the backend (10.249.48.1:8081) failed. [154.725665] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [154.725665] [INFO] MUDEC_00038: TCP relay from the client (10.254.245.162:54923) to the backend (10.249.48.1:8081) failed. [154.941132] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [154.941132] [INFO] MUDEC_00038: TCP relay from the client (10.254.245.162:54924) to the backend (10.249.48.1:8081) failed. [155.156816] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [155.156816] [INFO] MUDEC_00038: TCP relay from the client (10.254.245.162:54925) to the backend (10.249.48.1:8081) failed. [155.385145] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [155.385649] [INFO] MUDEC_00038: TCP relay from the client (10.254.245.162:54926) to the backend (10.249.48.1:8081) failed. [156.841394] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [156.841394] [INFO] MUDEC_00038: TCP relay from the client (10.254.245.162:54929) to the backend (10.249.48.1:8081) failed. [159.595170] [ERROR] MUDEC_00031: TOL_connect(10.249.48.1, 8081) failed: 61 Connection refused [159.595673] [INFO] MUDEC_00038: TCP relay from the client (10
Could you please check it again?  I think now this should be fixed.  It seems there’s a problem at mudfish node. :-(
