Hi, I’m not sure if I am doing my node settings correctly, but after equipping my Aion item, and tried connection with the NA server, I am still getting 356 ping+, which is about the same ping as without mudfish,
However on my Mudfish RTT chart, it shows that Aion’s MS is at stable 189, with connection to the best RTT node recommended (which was a 1 way node to Taiwan, Google). Have I done something wrong?
Yes I have, but my ping is still unstable, ranging from 200-300+
I also noticed from the rx/tx graph that the transmission of bits are not constant? about every 5-10 seconds no rx/tx bits are present
