Hi, I’ve been using MudFish on the game that I’m playing RF Online and it was working quite well the past few weeks but suddenly my ping got 70-100+ higher. I’m not sure how it’s happened and I doubt it’s my ISP but I wanted to ask how do I know if its a node problem or traffic as I’m not very well versed with regards to how MudFish works. Any advice is appreciated. I am on a Pay-Per-Traffic status right now.
Please be aware that recently I get some feedbacks from AU users when they connect to SG. If I know correctly there’s an international submarine cable issues so the routing is changed at this moment.
Do you think they’ll put it back to the way it was before? Do I have any other options that I can do to lower the ping close to what it was before? I’m not very good with MudFish and I might rely on what information you can give me. Is Full VPN good to use in these types of situation? I’m open to ideas and instructions if you can guide me. Thanks a lot for replying Ioxch
Definitely it’ll be back but not sure when it’s recovered.
Unfortunately there’s no good option for this case because this is international submarine cable issue.
You should find a mudfish node which provides a bypassing way. If you can’t find, it means there’s no other options.
Nop.
