Hi loxch,
sorry to trouble you again but i have some question need answer.
1. is it normal every time i run Mudfish and it ask to add a network adapter thing? Currently its already network 11.
2. is there a way to determine which combination of nodes work best all the time? or its better to configure every time i run into high ping using Mudfish?
3. sometime my ping when using Mudfish is way way higher than without using it why is that?
again sorry to trouble you and thank you for your support.
Here are my answers:
1. Unfortunately yes. Sometimes you should clean up these based on Merge network profiles link. :-(
2. This question doesn’t have a easy answer because depending on time, mudfish node status, game server status or your ISP status its result would be very vary and changable. Only what I recommend is FAQ - Nodes link about how to pick a better node.
3. Yes it could have because depending on which mudfish node you’d picked its RTT is changed. Please see above FAQ - Nodes link. If you’re interesting of network analysis between your desktop and mudfish node, you can try to use WinMTR or pingplotter tools to see which hops have a problem at that moment.
roger that, thank you for clearing my doubts much appreciated. great support.
