Hi mudfish used to work for me
Hi mudfish used to work for me but for the last few weeks until now i have been encountering stuck at 10% and the dashboard looks different than before that shows blank in background or images and the graphs are blank too.
I try everything from basic and setup keep loading only . Everything is ticked but noting is working
However are you meaning that you can see ‘text’ but can’t see ‘images and graphs’?
Ooops. It seems it failed to load CSS and Javascript resource files. :frowning: Are you under the network firewall? Or is it always reproducible after turning off Mudfish completely?
Its always like this when i use the program and after it launch on the explorer. Normal mudfish.net works fine.
That’s been happening to me as well for the past few weeks, I’ve found that pressing the home button up the top left seems to make it refresh and it works properly afterwards, kinda annoying having to do it every setup, but it works.
