Hi. My latency is not better w
Hi. My latency is not better with Mudfish :(
Can i have refund? Thanks.
Sure. :-) I’d refunded it.  It seems you didn’t pick a mudfish node you’d like to use based on FAQ - Nodes.  If you feel it’s not working well, you can also try to see Unsupported Games link.
Hi, I will try again :)
I use linux now, is there any guide for it to work on Linux?
Thanks!
Hi, i did everything correctly,even set node manually.
However, my latency is still higher using Mudfish than before using it.
Can you help? Thanks.
