hi, my mudfish is not working,
hi, my mudfish is not working, i’ve been trying and asking for so long, my IP dosen’t change, game: Bless
Need some help, ty.
Fixed thanks, anyway i lag so much in game it’s may depend because i have subscription and not pay per traffic?
When I checked your data plan, it seems your data plan is Subscription. However did you try to change a mudfish node based on FAQ - Nodes section for your game item? If you’re using the advanced mode, please start with the basic mode.
