Hi Still experiencing issues connecting with this account kvetinka I was wondering if there were any resolution?Thanks
Could you please explain little bit details? I guess your problem is that it takes long time to connect a mudfish node, right?
However how did you check that it’s?
Hi,Yes it can take a long time to connect to nodes with this account. My main account is gavlotic. Both pc’s are side by side so the time each client takes to connect to nodes is very obvious. When I connect via gavlotic it can take seconds whereas with kvetinka it can take a few mins.
Thanks
Umm… Not sure why but please try to do as follows:
Make sure that ‘Task Manager’ of Windows is running before launching a mudfish.
Run and sign in Mudfish.
