Hi there, is there a way for me to use VPN with android emulator on PC?
currently using NoxPlayer
Umm… Please check App Player section for details though I’m not sure it’s helpful.
hi there, im followed the instructions and able to connect, but when I go to whatismyip.com it says that I have connected to Seoul, KR instead of PH ETPI node that I have selected.
Is that normal?
Which method did you use? And what was the IP address from whatismyip.com?
