Hi, They added Hong Kong Servers to Battlefield 1 today. Can you please add its configuration too? From Bangalore, India to Hong Kong servers I am getting 320 ping now… should be 70 ideally
I’d updated the game item now. Could you please test it again?
I selected the Asia (HK) option in the item. the ping is 160… still a lot more than what I used to get in BF4 for HK servers
hey, I manually selected HK Azure 2 server and ive been getting great ping to HK (70). thanks a lot!
I also tried using this for Battlefield One but I cannot seem to see my ping in game. It’s at 0, do you also see this or how else do you check your ping because I’m not sure if Mudfish is actually helping me get better ping to HK servers
음… 혹시 중계 서버를 변경하시면서 시도하셔도 같은 증상이란 말씀이신가요? 일단 Full VPN 모드로만 된다면 먼가 게임 아이템 만으로 제대로 안된다는 뜻인데, WoT 의 경우 이런 일이 그 동안 없었던 지라 먼가 조금 이상합니다. ㅠ.ㅠ
왜그런지는 모르겠지만 어제부터 되네요. 수고하세요.
Please check http://mudfish.net/forums/6/topics/38498 topic for my answer.
