Hi why ful vpn dos not work?
I’m not sure this issue is related with the following error:
[477.766327] [ERROR] re61: MUDEC_00262: ODR_sendto() error to 46.101.228.155: Message too long. Check your path MTU. (curmtu 1450 buflen 1464)
Is it same if you change the connection protocol from UDP to TCP found under “Setup -> Program”?
