Hi would it be possible to add the Australian Overwatch servers to the list for finding an optimal route? Thanks
I believe this is the IP to the oceanic group server 103.4.115.248 I was provided this IP by Blizz support to run some test. I am also from Australia and would appreciate if we had an option for Destination server please.
Based on your configuration, not much except that it’d be better to use UDP than TCP as “Connection Protocol” option if it works properly.
If you’re familiar to use WinMTR or PingPlotter tools, you can test against 103.4.115.1 IP which is one of known game server IPs.
:-) I see. Please let me know if it’s not working properly again.
