how come i still get 250-270 ms for blackdesert SEA?
I don’t think there’s a proper route path between AU and SG at this moment because it looks like that there’s a submarine cable issue. Please wait some days until it’s recovered.
If you are connecting to SG you are connecting to the wrong server. They are located in Taiwan at the moment not SG. Try changing your server location to Taiwan instead.
What if I’m from the Philippines? Where should I connect and how do i change that? Thanks!
i changed to Taiwan server and playing without mudfish and with is the same 105-135 ms, i thought with Mudfish would bring down to 50ms.
