How do I check my ping while F
How do I check my ping while Fast Connect is on?
Unfortunately no way because all ping responses are from Mudfish program itself.  You should turn off to see  realtime RTT graph. :-(
Thank you for sending this problem report. :slight_smile: However is there any problem to use Mudfish? If then please elaborate little bit more for me.
