How do I connect to KR Overwat
How do I connect to KR Overwatch Server? It keep putting me in Taiwan Server everytime I use 2 nodes…
If I use Full VPN Mode it connects me directly to the KR Server I selected but it’s high ping, I need my traffic to be delivered to 2 mudfish node without using Full VPN Mode but the problem is even I use 2 mudfish node it connects me to Taiwan Server instead of Korea Overwatch Server is there any workaround regarding my problem?..
Okay… If you want to use ‘advanced node mode’ for this case, please test How to check the advanced node option working section whether your mudfish nodes are working properly.
