How to accelerate for supreme commander?
I play FAF
I see there is an existing item called supreme commander.
I equipped it.
Then I tried to select a node in Singapore, German, or leave it to auto selection.
I tried to turn on fast-connection, Full VPN mode, or simply turn off all options and stay in basic mode.
None of them seems to help me.
When I choose German node, the connection to others become extremely slow.
and, please advice on how I may use Mudfish properly
Thanks!!!
Hello,Thank you for reaching out to us. To get started, could you please confirm whether How to check the basic functionality is working correctly in your environment? This is the first step we recommend. If you encounter any issues, please let us know, and we’ll be more than happy to assist you further.
Hi, thank you.
I tried to turn on the fullVPN mode, and access https://myip.mudfish.net/.
I got
Okay. It looks good that this points that Mudfish works fine on your environment.
However do you know the game server IP? Or location? If possible, please check Packet Capture with Mudfish link and send us some game packets. We need it to analyze the game traffics.
We need to make sure that current “Supreme Commander” game item works fine to your game server.
Hi thank you for helping!
But I got this, it says internal error when I try to upload
:frowning: It’s not good. If possible, please check Packet Capture with Mudfish link’s FAQ section. You could send it to us manually.
Thank you!
I must be blind to not see this section…
Dear Weongyo,
I have send the email as suggested, I wish you have received it!
@herberthan Thank you for this update. :slight_smile: However it looks like I can’t find it properly. Did you send it to support@mudfish.net email address?
Hi, no, I sent to support@loxch.com as stated in the link.
I just send to support@mudfish.net now.
Please have a look!
thank you so much for the help
@herberthan :slight_smile: Thank you for sending the packet dump. Based on your packet dump, I had updated the game item. Could you please test with it? If it is not working properly, please let me know.
it’s working!
thank you very much
