hi, i’ve just installed mudfish to play dota2 (my university has blocked steam ports) and im getting the following error Error: MUDEC_000235
Too many heartbeats error. Please check your firewall.
here are the logs :
CORE:
[STDOUT] [0.025017] [INFO] mudfish v4.3.2 (for i386) [0.025017] [INFO] Timestamp: Sat Sep 19 00:00:50 2015 [0.026017] [INFO] Connection protocol: tcp [0.026017] [INFO] Authenticating… [0.919955] [INFO] Fetching the static node for v2… [2.662069] [INFO] TAP-Win32 Driver GUID {F283AA17-08E1-4918-AD01-EC2C986CD8F2} [2.663073] [INFO] TAP-Win32 Driver Version 9.21 [2.663073] [INFO] TAP-Win32 Driver MTU 1500 [2.663073] [INFO] Setting TAP-Win32 Adapter v9’s MTU to 1450 Ok. [2.706986] [INFO] TAP-Win32 Driver TcpNoDelay diabled [2.706986] [INFO] TAP-Win32 Driver TcpAckFrequency 1 [2.739509] [INFO] re0: Associating with ip 50.18.179.222 port 10008 [23.741345] [INFO] re0: MUDEC_00071: Couldn’t connect to 50.18.179.222:10008 for TCP: 10060 ODR_ETIMEDOUT [45.742884] [INFO] re0: MUDEC_00071: Couldn’t connect to 50.18.179.222:10008 for TCP: 10060 ODR_ETIMEDOUT [67.745981] [INFO] re0: MUDEC_00071: Couldn’t connect to 50.18.179.222:10008 for TCP: 10060 ODR_ETIMEDOUT [67.745981] [INFO] re0: MUDEC_00074: Failed to connect 50.18.179.222:10008. [67.745981] [INFO] re1: Associating with ip 46.137.251.232 port 10008 [88.750533] [INFO] re1: MUDEC_00071: Couldn’t connect to 46.137.251.232:10008 for TCP: 10060 ODR_ETIMEDOUT [110.750753] [INFO] re1: MUDEC_00071: Couldn’t connect to 46.137.251.232:10008 for TCP: 10060 ODR_ETIMEDOUT [132.753764] [INFO] re1: MUDEC_00071: Couldn’t connect to 46.137.251.232:10008 for TCP: 10060 ODR_ETIMEDOUT [132.753764] [INFO] re1: MUDEC_00074: Failed to connect 46.137.251.232:10008. [132.753764] [INFO] re2: Associating with ip 176.32.86.113 port 10008 [153.754609] [INFO] re2: MUDEC_00071: Couldn’t connect to 176.32.86.113:10008 for TCP: 10060 ODR_ETIMEDOUT [175.754410] [INFO] re2: MUDEC_00071: Couldn’t connect to 176.32.86.113:10008 for TCP: 10060 ODR_ETIMEDOUT [STDERR] Empty file.
FLOW CONTROLLER:
[STDOUT] #### shmc vsl| RUN 0 FlowSet - rtadd 103.10.124.0 255.255.254.0 -1 23 NA 0 -1 #### odr ===> Checking MTU to 14.63.214.216 #### shmc vsl| RUN 1 FlowSet - rtadd 103.28.54.0 255.255.254.0 -1 23 NA 0 -1 #### shmc vsl| RUN 2 FlowSet - rtadd 113.106.96.0 255.255.255.0 -1 23 NA 0 -1 #### shmc vsl| RUN 3 FlowSet - rtadd 113.107.216.0 255.255.255.0 -1 23 NA 0 -1 #### shmc vsl| RUN 4 FlowSet - rtadd 121.11.88.0 255.255.255.0 -1 23 NA 0 -1 #### shmc vsl| RUN 5 FlowSet - rtadd 122.225.32.0 255.255.255.0 -1 23 NA 0 -1 #### shmc vsl| RUN 6 FlowSet - rtadd 125.141.153.128 255.255.255.224 -1 23 NA 0 -1 #### shmc vsl| RUN 7 FlowSet - rtadd 146.66.152.0 255.255.254.0 -1 23 NA 0 -1 #### shmc vsl| RUN 8 FlowSet - rtadd 146.66.154.0 255.255.255.0 -1 23 NA 0 -1 #### shmc vsl| RUN 9 FlowSet - rtadd 183.136.230.0 255.255.254.0 -1 23 NA 0 -1 #### shmc vsl| RUN 10 FlowSet - rtadd 192.69.96.0 255.255.252.0 -1 23 NA 0 -1 #### shmc vsl| RUN 11 FlowSet - rtadd 208.64.200.0 255.255.252.0 -1 23 NA 0 -1 #### shmc vsl| RUN 12 FlowSet - rtadd 208.78.164.0 255.255.252.0 -1 23 NA 0 -1 #### shmc vsl| RUN 13 FlowSet - rtadd 222.122.133.0 255.255.255.0 -1 23 NA 0 -1 #### shmc vsl| RUN 14 FlowSet - rtadd 58.215.52.0 255.255.255.0 -1 23 NA 0 -1 #### shmc vsl| RUN 15 FlowSet - rtadd 61.182.135.0 255.255.255.0 -1 23 NA 0 -1 #### shmc vsl| RUN 16 FishGet - RoutingTable #### tmon Sleep 5 second ### adn No UID set yet #### rte Sleeping for 5 seconds #### bck Backend (50.18.179.222:10007 US) is added # rttd UDP: select timeout for 50.18.179.222:10007 #### bck Backend (46.137.251.232:10007 SG) is added #### odr . # rttd UDP: select ti
Or you can try to use Proxifier with Mudfish (Mudfish with Proxifier link). But I don’t know your network firewall allows a port 18081 (used for socks v5 protocol).
