I tried, but in vain.
Isn’t there any other method?
If it works fine with Full VPN mode enabled, you should try to use the item only without Full VPN mode. Are you meaning that even with this approach, you can’t access the PUBG (NA game server)? If then it could be a problem of the mudfish game item.
