I think Mudfish is a joke, eve
I think Mudfish is a joke, even when I quit the client, the game is still running… I did it because I suspected my connection has not been routed through Mudfish connections since before and after enabling the game optimizing, there was no different. Quite disappointed :(. But when I changed to wtfast and BattlePing, it was a whole new difference…
Please confirm that How to check the basic functionality works fine in your environment. It’s a first thing you should test. Sometimes there’s a problem at mudfish game item itself.
I did tried Full VPN connection, it worked fine meaning my Mudfish was working correctly. I tried Mudfish on Lineage 2 North America server and it didn’t seems to work.
If you tested correctly, it means there’s an issue at Mudfish game item itself.
Packet Capture in Full VPN mode with Lineage 2 has been uploaded, please check, thank you!
Thank you for sending the packet dump. I’ll add my comments at the packet dump topic.
