I went ahead and setup for Bla
I went ahead and setup for Blade and Soul, but I’m not getting the ability to connect to the server once connected. How can I fixed this? I did the -I and getting an IP address, but fails to connect on nearly all Central Dallas Servers
After tinkering with almost every setting, firewalls, AV, everything, I’m going to request a refund. Not working out for me. Shouldn’t be causing this much of an issue for a tunnel. Plus, was coming across a technical bug - once I logged out and back in for configuration(s), it wouldn’t reconnect. Had to restart the application/service.
No problem. :slight_smile: I’d refunded it now. Thank you for interesting to Mudfish!
Did you try to check How to check the basic functionality works fine in your environment? It’s a first thing you should test.
