Hey,
I live in Vancouver, I just bought credits for Mudfish. I just want to use it to play Blade and Soul. Can you guys tell me the best to set this up or can any technician check if my current setting is correct ??
Thanks
Hey,
Thanks
Hello monkeyssimo,
First you should check the process status on the dashboard whether it’s good or bad. If it’s good and “Ready” message is shown at Log section of ‘Status → Process’, it’s ready to use. However to set up a game routing path, I think the best way for that is using Wizard menu which be available at ‘Settings → Wizard’. Please let me know if you have any issues.
보통 아이템 관리 메뉴에서 해당 아이템을 찾으실 수 있으실 것입니다.
혹시 여전히 이슈이시면 댓글 부탁드리겠습니다.
네 감사합니다
