[INFO] [MUDEC_00080](http://mu
[INFO] MUDEC_00080: TOL_sendto(2) error to re266 10.232.16.1 (TW Asia (Taiwan - HostingInside 6)) for heartbeat (-1 64)I always get this kind of INFO recently. What does this mean?
This error message means it failed to send a heartbeat packet to the target mudfish node .
However if its error level is “[INFO]” not “[ERROR]”, you can ignore
this error message because it doesn’t affect your connection
= Solution =
  • Please try to change a mudfish node to others
  • Or please try to change “Connection Protocol” found under
    “Setup -> Program” menu.
  • Or please contact to the mudfish forums.
[60.850420] [ERROR] MUDEC_00235: Too many heartbeat errors. Blocked by network firewalls? I can see errors now. BTW,I based in China recently. Seems I have problems with connecting to master servers.
Ooops… :frowning: Then did you try to change Connection Protocols to another?
Sure. Only TCP 443 can work sometimes.
Weird… Are you under network firewall then? Without thinking of firewalls, I can’t imagine what it causes.
Sorry. I find out TCP can work. Not only 443. But not UDP.
