Is it possible to run (2 mudfi
Is it possible to run (2 mudfish (with one account + 1 alias) on same computer with different TAP adapter? TAP1/TAP2 (addtap using openvpn))
I want to do this
Client1.exe - Bind to TAP1
Client2.exe - Bind to TAP2
Remote server i want to connect to : this.is.server.ip
using mudfish to:
Client1.exe connects through mudfish to this.is.server.ip using node1
Client2.exe connects through mudfish to this.is.server.ip using node2
so server sees client1 and client2 from different ip address
Nop. You can’t because Mudfish and OpenVPN uses same TAP network adapter.
