Is it possible to use Mudfish only for games? I know it’s a system-wide VPN but was wondering if there were any exe-hooks to limit Mudfish to only games, as I wish to stream my gameplay but do not need Mudfish for that cos it will consume all my data. I can see my data usage graph spike up when I refresh webpages, and even Teamspeak is routed through Mudfish even when Full VPN is not enabled.
If you’re not using Full VPN mode, the traffics which aren’t related with games should not be passed by Mudfish. However because Mudfish’s working based on the routing table of OS (not exe-hooks), the unexpected traffics could be passed by Mudfish. Specially for Overwatch, this issue is existing because it’s on Amazon EC2. :-( It means that if your teamspeak server or CDN is also on Amazon EC2, it could be passed by Mudfish.
To completely avoid this behaviour, you should use Proxifier (not sure it’s working fine with Overwatch).
