It seems none of your Final Fantasy 14 nodes for Primal Appear to be accurate. I seem to be getting ping spikes every minute or so
Multiple times, all the nodes that i pinged seem to all spike
These were taken 20 seconds apart, please help
Please check your ISP first. When I checked RTT information recorded in Mudfish, it seems RTT stddev values to most of the mudfish nodes are little bit unstable. It means your ISP has a network issue. For details please check http://ko.loxch.com/userrtt/?uid=287873 link.
I don’t think its my ISP, no other game do i get ping spikes, Im just trying to reroute my traffic.
Did you try to use WinMTR or PingPlotter tools to see where these spikes are from? If your issue isn’t really from your ISP, I think you should analyze this issue little bit more.
