i've got problem again with bl
i’ve got problem again with black desert online, its keep disconnected
already do some changes but still cant solve this problem- changing nodes - turn off full vpn- turn off fasconnect- use UDP protocol- check core logs on process no error message found
please help
thanks,
Not sure at mudfish side too. :-(  When I checked your error logs, most of them are related with FastConnect mode.
However where do you live?  Or are you using other VPN program?  Your connect IP is from Amazon EC2.
I live in Indonesia, and im using mudfish as VPN and no other VPN use
yesterday no problem with black desert, somehow it’s repair by itself but it’s keep disconnect on other day, i post on technical support chat only when it’s come to problem
thanks for your reply
thanks for replying, i’ll check to my ISP
No problem! :-) Please let me know if there are any other problems.
it’s working now! thanks for the update.
