League of legends client not working
League of Legends: when I connect to the VPN, the game client doesn’t work. But when the match loads and I start the VPN, the game works fine. However, the client doesn’t work. Every time I finish a match, I need to disconnect the VPN and open the client, find a game, and then start the VPN.
it doesn’t work same issue
At that moment, was WFP Item mode enabled or not? If it was enabled, please try to turn off and test it again with Full VPN mode enabled.
it was off please give me full answers so i could test them all cuz the replay from ur side take time and i want to solve the issue cuz its annoying
Sorry for my poor answer. It looks like your issue is even same with Full VPN mode enabled + WFP Item mode disabled…
For this case, it’s hard to say why this issue happens. I think How to check the basic functionality link worked fine on your environment. With this assumption, I don’t think there’s a thing missed because we can assume that all traffics went through the mudfish node.
Please try to test with mudfish nodes first though I’m not sure that it’ll work for you. If it’s still the same with other mudfish nodes, it could be more related to a conflict between mudfish and the game client.
You can try to create a custom game item and just use the game server for mudfish. This means the client and vanguard will be direct but when you connect to a game it will be through mudfish nodes.
If the only reason you use mudfish to to get lower ping this is the best solution. What region do you play on?
