May I know how can I help to open up a node for EU Bless Steam version?
Unfortunately it’s not officially supported by Mudfish yet. As workaround you should use one of methods at Unsupported Games. And if you want to see it officially at Mudfish, please send me some game packets using Packet Capture with Mudfish link while playing the game with Full VPN mode.
I need some game packets to register new game.
As i have done it before, I dont mind doing the packet capture,
I hope you will monitor it ASAP
Recently I’d updated EU destination for Bless Online. Could you please test it again? Please let me know if it doesn’t work properly.
i tried it out yesterday, im not sure is it because of the node i was using, there was some big spike and occasional freezing in the game, some node i try i can’t even connect past the launcher as it writes “network connection unstable”
Umm… Might be the unstable connection issue would be a different problem in my opinion. However could you confirm that with current mudfish game item it works to access the game without Full VPN mode enabled?
yes it works, because once im connected to it and the game, and i off mudfish, it dced my game, so im pretty sure it works
Okay… Good to hear that the game item works fine. Then please check FAQ - Nodes to know how to pick a better mudfish node. I think it’d be better to use ‘Basic Mode’ rather than ‘Advanced Mode’ if you want to get a stable connection.
