Moonlight Blade doesn’t work for Korean servers. Fails to connect to the servers for some reason. Tried multiple servers.
Yes, it is the same with Full VPN mode enabled.
Then something is wrong. Which mudfish node did you pick? Please try to use mudfish korea nodes with Full VPN mode enabled.
