Mudfish node giving higher ping than it says in RTT table. So I’m trying to connect ESO (the Elder Scrolls Online) via mudfish to NA server and currently trying Basic method.
I Updated the RTT table and chose JP Asia (Tokyo - SakuraNet) since it gave 2nd lowest Score, and had flattest RTT graph from top 4. The expected ping is 272 according to it, but ingame my ping is varying from 296-330.
Also, I can’t seem to bring up the RTT table for Advanced node setup, keeps giving me error that too many requests have been sent.
You should consider RTT stddev values because it points how much your internet connections are stable. When I checked the result of http://ko.loxch.com/userrtt/?uid=288826 link, it seems your ISP have some stability issues because its RTT stddev values are relatively high. When you get a chance, please check your ISP too.
Please wait 1 minute and try it again. For most of cases, it solves this issue.
